07 TaG weights
Home Forums General Discussion 07 TaG weights
Viewing 15 posts - 1 through 15 (of 60 total)
  • #41834
    Kirk Deason
    2006 weights:
    Engine………………………… WKA TaG.. TaG Sr….. TaG Mstr… TaG Hvy
    Biland Stealth old exh……… n/a lbs…. 370 lbs….. 400 lbs….. 415 lbs
    Biland Stealth new exh……. n/a……… 375………. 405………. 420
    BM Jaguar…………………….. 355…….. 360………. 390………. 405
    Comer………………………… 385…….. 390……….. 420………. 435
    EasyKart………………………. 355…….. 360………. 390………. 405
    Italsistem ML47H……………. 385…….. 370……….. 400………. 415
    Motori Seven…………………. n/a……… 360………. 390………. 405
    Parilla Leopard………………. 355……… 360………. 390………. 405
    PRD fireball……………………. 355…….. 360………. 390………. 405
    Rotax FR125…………………… 350……… 360……… 390………. 405
    Sonik TX125…………………… 385……… 390………. 420………. 435
    Sonik VX125…………………… 375……… 390………. 420………. 435
    Vortex Rok……………………… 355…….. 360………. 390………. 405
    2007 weights:
    Biland Stealth ………………. n/a lbs…. 390 lbs….. 420 lbs….. 435 lbs
    Motori Seven…………………. n/a……… 370………. 400………. 415
    Rotax FR125…………………… 350…….. 360………. 400………. 415
    Sonik TX125…………………… 385…….. 390………. 420………. 435
    Vortex Rok…………………….. 355…….. 360………. 390………. 405
    ATK…………………………………………….390………..400………..415
    PCR…………………………………………….400………..400………..415
    CRS 125………………………………………390………..420…………435
    Super ROK…………………………………………………………………440
    So uhhh, does this mean I get to race this summer with NO WEIGHT on my Easykart? :idn: Or does one take a skeptical view and say that Easykart didn’t pay a homologation fee and thus the removal from the ‘approved’ list?
    I assume I’ll still be able to race at last year’s weight, correct?
    #55864
    Tom Dennin
    Here is the questions I have:
    1) Why did the Rotax weight get increased 10lbs and the Leopard weight stay the same? The leopard was either superior or even at all tracks.
    2) In 2006, the biland with new and old exhaust were differentiated by weight. Now in 2007, TAGUSA only has one weight for both? and they increased the weight by 15lbs?
    Tom
    #55865
    David Watkins
    I have the same question. Why was the weight increased for Biland? There are now three versions with each version making more power. Why would the original lower H.P. version suffer a weight increase? Will the CSC follow these weights?
    #55866
    Jon Romenesko
    Yeah, what gives?! I certainly don’t like that… 😕
    #55867
    Joe Rosse
    And it makes even less sense for TaG Junior. Rotaxes (in Junior configuration) were at a disadvantage at last year’s weights, and now they’re adding 10 pounds to the Rotax Jr. and keeping the Leopard at the same weight??? You’d have to be crazy to race a Rotax in the Junior class!
    #55868
    Tom Dennin
    Instead of a TAG classs, why don’t we just call it a spec Leopard class? 😆
    #55869
    hotwheels1517
    Since the motor does not make a big difference and it’s all about driver and kart setup why are the weights differen’t? While im on that subject why do some racers have more than one engine package for there respective classes? So confusing 😕
    Brian Moore
    #55870
    Greg Welch
    Even though it is mainly kart and driver, it is nice not to start at a disadvantage. I have this feeling though that the weights will be back to 06 specs fairly soon 😉
    #55871
    Doug Welch
    I just received an email from Marty Casey with TagUSA. The Rotax weights will be back to ’06 weights as soon as the web mistress gets it done.
    #55872
    Kirk Deason
    Thanks for the correction, Doug. I edited my post to reflect the corrected Rotax weight at 360.
    #55873
    jj
    It seems strange to me that the Leopard is rated around 23hp while Rotax claims 27 hp, yet peole want to let the Rotax run at the same weight. ???
    the whole point of having weight differences is to make up for differences in BHP and either Rotax is not putting out what they claim, or they should have a weight penalty to even things out. this should be easy to check on a dyno.
    #55874
    cgordon
    Peak hp is not the only indicator of an engine’s performance. On the dyno sheets I saw, the Rotax was the peakiest of the TaG engines. The Rotax may have the highest peak hp, but only over a relatively short rpm range. The other TaG motors have much flatter power curves, so they are stronger at lower rpm ranges.
    The maximum rpm that an engine can turn also affects performance. Some of the other TaG motors turn more rpm than the Rotax, so on a track with a wide range of speeds shorter gearing can be run on those motors for the slow corners and they still won’t run out of revs on the straight.
    Finally, on track results are a real performance indicator. We saw several different types of engines running up front this year. If the Rotax was dominant everybody would be switching to it, and that certainly wasn’t the case.
    Charles
    #55875
    Brad Linkus
    The Leopard is not 23hp it is close to 28hp.
    #55876
    David Watkins
    Anybody have any ideas?
    #55877
    Rodney Ebersole
    To make the market better for the new’est higher powered and priced Biland.
